Discuss Best flexible tap connectors for bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can someone recommend a go quality flexible tap connector for a bath 3/4 Bsp and would it be advisable to go for a full bore connector.
Water is supplied from direct invented tank
Thanet
As above stick with WRAS approved flexis with as large a bore as you can get . kop
Reply to Best flexible tap connectors for bath in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
