- Messages
- 337
Servicing your heating system shouldn’t be difficult, and it’s even easier when you are using one of the fastest filters on the market – the Magnaclean Professional 2 Filter and Chemical Pack from Adey is the product for you.
When using the Magnaclean Professional 2 Filter and Chemical Pack, debris is captured with twin reverse flow which helps to remove sludge and other materials that are affecting the efficiency of your heating system, which in the long run helps save you money on heating.
Feature and Benefits:
- In-line style installation
- Quick fitting
- Compact unit for use in small spaces
- Maximises debris capture
MC1+ Protector:
- Concentrated, high-performance inhibitor to maintain heating efficiency
- Able to treat 125l / approx. 15 radiators
- Suitable for use on all heating systems
MC3 Cleaner:
- Powerful formula for better clean
- Ideal for open-vented, and sealed heating systems
- Cleans: debris, sludge, corrosion, and other materials
- Cleans approximately 125l / 15 radiators
