Discuss Best way of joining 1.25 copper to 28mm copper in the USA area at PlumbersForums.net
I have recently moved into a new home (old house) where the pipe from the boiler to the cylinder (indirect vented) is 1.25 inches.
I need to change the cylinder and was wondering how best to join 1.25mm copper to 28mm copper for the new tank.
Any advice would be gratefully received
35mm - 28mm just make sure it’s copper not steel
Easy to tell will measure 35mm / if you find a fitting will be listed / written on it on the nut front face
This may help. 3 pictures with dimensions in cm and inches on a digital caliper. it has paint on it.... so its going to be a fraction smaller
Would get this just incase
Just make sure the new cylinder is suitable for gravity hot water heating side most arnt
Best to email gledhill if your not s or y plan
Shaun, I wanted to thank you for your advice.
I rung the supplier of the cylinder this am and asked them to ensure it had a gravity fed coil.
They called gledhill and they changed the order. They will supply this with a gravity coil and its only £18 extra.
If it was not for your help, I would have probably had to send the cylinder back and that would have been painful.
Thx once again
Adrian
Reply to Best way of joining 1.25 copper to 28mm copper in the USA area at PlumbersForums.net
