Discuss Biasi compact he mk2 47-583-18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello,
My first post im a registered engineer, not used forms before so hoping I've posted this right?
I have attended a no heat or water on my neighbours bias compact he combi,
Fan would not opperate, they were no power at the fan and fuses good so I determined that is was a pcb fault.
Replaced pcb- fan now operates but.
Only fires for hw not for heat when called for,
Also the actuator on diverter valve does not opperate.
So I now believe that the air pressure switch maybe faulty as well as the diverter actuator.
Could it be that these parts could have been damaged from a power surge when the pcb packed in?
Firstly welcome along. We do not discuss gas appliance issues in open forum however we do have a sub forum devoted to it.
What we need you to do is make a few more posts 10-15 should do. Introduce yourself, try and help a few members with their queries.
Then send an image of the front and back of your GS card to either @ShaunCorbs @Harvest Fields or @Riley and we will arrange access for you
Cheers Riley,
I will send you a picture of my card.
Im just trying to get back out on the tools again so a bit rusty on fault finding on the newer appliances, been working at a college for some time now so 80% of my plumbing knowledge is all pipe bending calculations and bending skills
. 3.14159265359 3.14159265359 3.14159265359 LOL i will have to delete some of that from my memory
I've found the parts were not too expensive so I've ordered them and try and see how I get on.
Reply to Biasi compact he mk2 47-583-18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
