Discuss Biasi garda he silver (fault ) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
richardd
The problem I am having is the hot water cuts out after a tap has been open for 30- 40 seconds. When you turn the tap of it resets itself and will work next time you open the tap for 30 -40 seconds only. I have taken the flow rate down to 12 ltm and the problem still happens. I beleive it is the dhw flow or temperature sensor sensor needs replaced.
Has anyone else came across this. I want to go straight to the problem saving time and cost and dont want to be replacing a pcb if possible. ANY IDEAS THANKS IN ADVANCE.
Reply to Biasi garda he silver (fault ) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
