Discuss Biasi M90E no DHW or CH in the Canada area at PlumbersForums.net
PDS
Hi Guys, called out to a Biasi M90 with no DHW or CH. ignition pcb was faulty but since realised that there is no live to that board. I have a live feed into the main board and fuse is good. Do we reckon it’s the main pcb that’s at fault?
Overheat stat fine ?
Pump running when demand or just totally dead?
No voltage to fan ?
Check the pump proving circuit
as shaun said is spindle coming out on pump proving and operating the microswitch assembly on the left hand side of the boiler. if you take microswitch off its housing by removing the spring clip then turn on so pump running then push a small screwdriver into the hole to operate the m/switch and boiler fires up you need to change the diaphragm on pump proving assembly
Pcb then I would say
Reply to Biasi M90E no DHW or CH in the Canada area at PlumbersForums.net
Hi, As per the thread title, I have an Ideal Logic Combi 30 and I am having a problem with the pump, which keeps activating without any DHW/DCH...
1K
Hi hoping someone can help with this as its beginning to drive me nuts. Boiler generally well serviced and working fine, no problems with DHW...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
1K
Hi all, Just looking for some advice if anyone has worked on a boilermate 2000 try to condense the story, Lived in our home 3 years with the...
