Discuss Biasi M96.28SM/C2Hi guys hoepfully someone can help me. the frost protection light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pgas
Hi guys
the frost protection light sequence is flashing. The boiler is in the garage. Would that suggest there is a frost stat on the wall? Or in the actual boiler?
Timeclock - seems to have 6 settings, I've never known a boiler to give you the option to set 6 times. Is this correct?
It's hard to explain what the problem is, I need to get rid of the frost stat lights before I can continue fault finding.
Customer is saying they can only turn the boiler on or off by turning the wall stat up or down, even when I set the times, the boiler does not come on, yet today the boiler came on without creating demand, and I think the frost stat has something to do with it.
they are also saying the 'click' on the room stat seems to be set at 16 degrees, the click never moves position if you will.
any suggestions welcome if anyone has come across this...
thank you.
Reply to Biasi M96.28SM/C2Hi guys hoepfully someone can help me. the frost protection light in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a conventional system, Potterton Prima Boiler, into a Pump into a Motorised Valve that feeds the Radiators and/or the pipes in the Hot...
Hi guys, first post here So I have been boxing in a number of heating pipes that are throughout my garage since the boiler was located there by...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
