Discuss Bit of a noob question... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pete3690
sorry for the silly question guys, my minds gone completely blank lol
Whats the best compound/name of the compound to use on compression fittings?
I use jet blue plus when i do. but most of the time you dont really need a paste on compression.
Nothing.
Sent from my GT-I9100 using Tapatalk
Ahh ok then, Just at college they had suggested a bit of compound/paste around the olive, but I suppose its down to the person fitting it, everyone has different ways I suppose :)
a small amount of "boss white" around the edge of the olive will not hurt, especially on heating systems/controls like rad valves and zone valves (ie where things get very hot). Just make sure its just a little smear, to many times ive had to unblock things due to peoples overuse of jointing compound. Try to avoid using it on any valve that has a filter.
if you are using jointing compound be careful what you use as the likes of boss white is not suitable for potable water
jet blue can be used on everything, so that is my preferred choice, but i keep losing my tub and havent purchased another in a while although not really need it as i only really ever used it when joining onto existing compresion fittings dont use anything on new compression fittings.
Nothing on new fittings, If reassembling old jet blue for water / heating or heldite for oil
Reply to Bit of a noob question... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
hi all i hope you are all well i'm planning to install my shower mixer on Saturday. today i was doing a dry fit and i wanted to show you some...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hi have surplus water feed and return pipes in my home. I can't isolate them so will need to freeze. House built 1970's. They're as far as can...
Hi everyone, I'm new here! I've bought my first house - needs a fair bit of work doing to it, including the plumbing. I'm keen to do stuff...
