Discuss bleed screw snapped in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bob the plumber
as above? any tips on getting the bloomin thing out as its built onto the rad? radiator cost £500 so cant imagine the customer will want to replace it. They did it not me :)
I have thought about either drilling it out with a small metal bit but this could damage the thread of the rad
or
hitting it with a flat screwdriver to somehow create a groove in it to be able to take it out with a flat screwdriver?
thanks in advance for the advice
bob
Get a screw remover. That should do the trick
Only good if you are patient and don't run the drill quickly. Plus you will need to be pushing quite hard.
I've had mainly success with them, but the set I've got is a little better quality than the Rolson one.
From Screw Fix....
Trend Pro Grabit Screw and Bolt Remover 2 Pieces
Suppose if screw remover fails, hopefully it won't, you could always drill it out & tap it for a brass bolt. Any of those very tight air screws are best removed & carefully cleaned of any paint, that some of the new rads have in them. Makes a big difference. Also a very slight touch of copper grease on threads of screw helps forever.
Be very careful using stud extractors - generally thought of as the tool of the devil in engineering. If you snap one off (which is easy to do in the small sizes) you need to get the remains spark eroded out as they're too hard to drill (obviously next to impossible and not worth it on a rad).
I'd centre punch the remains of the air screw accurately and drill it out carefully working up in drill sizes until you're nearly at the threads. Then use a fine pick to remove the remains of the screw. You're going to have to be careful not to drill into (or even through) the bleed screw seat. I've done this loads of times over the years on motorbikes - not too hard after a bit of practice.
It's going to be much easier to do this with the rad off the wall where you can attack it comfortably.
Reply to bleed screw snapped in the Plumbing Jobs | The Job-board area at PlumbersForums.net
