Discuss Blocking Up a Gap in Waste Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have recently removed the broken dishwasher we inherited with our new house. The waste pipe for the dishwasher was connected to the same waste pipe for the washing machine. Now the dishwasher and its waste pipe have been removed it has left a open gap (see picture). Due to the waste pipe for the washing machine being inserted above I need to block off the gap below. What is the best (and quickest) way of doing this? Can i get some sort of a plug/stopper to put in it?
Any chance of a few more pics of the black pipe where it goes etc
Looks un trapped
If it was me, I’d cut the vertical pipe just below the dishwasher connector, then, cut off the connector, and get a 40mm straight push fit connector from B&Q or similar and put the pipe back in.
The vertical height will only be about two inches lower and should not make any difference washing machine waste.
A washing machine/dishwasher waste is supposed to have a trap. If it has a trap then yes you can do what is mentioned above. If not fit a washing machine standpipe but as shauncorbs said a couple more pics would be good.
Only been a plumber for 12 years and never come across a standard push fit fitting fitting solvent pipe...push fit adapter coupling yes.
I have never had an issue. Maybe I have been lucky or non of the pipes have been solvent?:p:p
Very old I think marley fits normal solvent waste
A compression waste coupling can usually be made to fit but King of Pipes has the best solution, especially if the W/M waste doesn't already have a trap.
Reply to Blocking Up a Gap in Waste Pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
