Discuss Boiler and water pump in the USA area at PlumbersForums.net
Hi all,
let me set the scene
boiler in downstairs kitchen
Water pump? (red thing in airing cupboard upstairs)
the pump is loud enough to hear downstairs the drone or humming is noticeable and The boiler fires upat the same timethis all happensif heating ison or not
the pump gets so hot you can’t touch it any longer than a second, it runs stops for a second then goes again
If I had to put numbers on it I would say pump runs at least 18 hours a day on and off
the boiler fires up like every 5-10 mins too
yesterday I was out the front and smelt gas which I believe came out the flue Don’t often smell gas though
any advice do I need it looked at,
Thankyou
Perhaps turn your boiler off, turn your emergency control valve off (should be where your gas meter is - if you have one?) and either call emergency service as Keefy suggested or call a gas safe registered engineer for the 2 issues.
Safety first deal with the smell of gas isolate your boiler and your gas supply at the gas meter control valve and contact the emergency services as above , then employ a GSI to test your supply and the pump issue . Kop
Reply to Boiler and water pump in the USA area at PlumbersForums.net
Pumps and low pressure I moved the bathroom to the back the house (next room) upstairs. I put in two pumps because low pressure water area. One...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
Hi all, I’m looking for a bit of advice. A flat two stories up from mine has installed a water pump that feeds all of their outlets (shower...
