Matt0167
- Messages
- 57
HI Guys and girls hopefully someone can help
went to a breakdown over 2 months ago, no hot water and heating , took the case of and called for heat, fan started but Aps didnt make, tested switch no making and breaking went and got a new one , and hey presto all working fine ..
2 moths later get the call ...... you know that boiler you fixed its gone off again .... went out took the cover off as before called for heat , fan went Aps clicked over but didnt carry on the sequence tested the pressure switch working fine pulled the tubes off checked them , they were fine as soon as i put the positive tube back on Aps clicked over and it fired , put everything back together called for heat a few times everything working as normal
day later get a call again boiler back off , so now im thinking fan venturi went there took case of pulled the positive tube off put back on and hey presto fired up again , turned everything off took fan out checked venturi not damaged or blocked , fan is working no unusual noise ?
boiler is the old 24i Junior . GC 47-311-69
Anyone got any ideas , as im sure ill be back there in a couple of days
thanks in advance
Matt
thanks in advance
Matt
