Discuss Boiler fumes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
johnyreb
A friend's neighbour has just had a new gas central heating system installed including a condensing combi boiler. The boiler has been installed in an upstairs bedroom cupboard with the flue terminal fixed flush on the outside wall approx 200 mm below the wooden boxed in section beneath the drainpipe. Depending on the wind direction the fumes are unable to rise clear but are driven along the bottom of this wooden box section and into my friends bedroom window just further along.
Is there anything he can do about this.
Your friend should ask the neighbour to get a plumage kit fitted to the flue,this can take the plumage above the soffit,to stop it running along it,as it is doing
Thanks for the reply, my friend does not wish to fall out with his neighbour who had his system installed by sub contractors. If his neighbour or the contractors refuse to do anything about it is there anything further can be done, ie is there anyone who could come out to inspect it as a health issue. Another thing that concerns him is that the boiler safety valve outlet pipe terminates a couple of feet above the entrance to his front door.
You can complain to Gas Safe about the flue position if the flue gasses are causing a nuisance. All of the distances that the flue must be from openings, parts of the building, other properties etc. are all in the manufacturers instructions but there is normally also a note that they shouldn't cause a nuisance. This can be open to interpretation but with products of combustion entering a property it sounds fairly clear cut to me.
The safety discharge pipe should not terminate above a door or window.
If their not already tell them to Keep the window shut till its sorted
I really doubt that Gas Safe will do anything unless the neighbours grant access for the 'free' inspection. I would first speak with the neighbours and explain the concerns, and see if you can reach an amicable solution.
If no budge from neighbours and/or their contractors, then Environmental Health is the next port of call. Flues can be perfectly installed to manufacturer's clearance; however there's always that little line about not causing a nuisance. If an Environmental Health Officer deems the flue position a nuisance, then they can force the neighbour to rectify or shut down.
Reply to Boiler fumes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I really hope someone can help me because it is causing so much worry! I bought my house 3 years ago and didn’t know at the time that...
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
1K
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Worcester Danesmoor 20/25, about 18 years old. B11 burner. We came home a few days ago to find our boiler in lockout, and not wanting to restart...
2K
