Discuss Boiler leak suddenly overnight in the Oil and Solid Fuel Forum area at PlumbersForums.net
Good morning, My old RHINO boiler has developed a small pin ***** leak at this plastic joint, its a threaded cap with some wire coming out top, any one know best cure ? Thanks
Flow switch common fault
As Shaun says it's a common problem with flow switches. This needs to be replaced sooner rather than later. Ive known leaking flow switches to take out PCB's and damage burner components
Most of them use the same eg Worcester warmflow
many thanks gents will try to find one, quite old boiler Rhino
Just google your boiler make and model flow switch, you should be able to find one. Alternatively you might be able to adapt with a different make, a flow switch is just a paddle inside that connects a live and switch live
Reply to Boiler leak suddenly overnight in the Oil and Solid Fuel Forum area at PlumbersForums.net
Hello everyone, Baxi Ecoblue System boiler which was recently serviced just before Christmas. There has since been a constant but slow drip...
Hi, I need some urgent advice. I've Just come home after going out for evening, to discover hallway floor and kitchen floor covered in water. On...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the...
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any...
We had the bathrooms replaced when we moved in 2 years ago. This involved 2x bathrooms and 1x WC. Within the first few weeks, we noticed leaking...
