Discuss boiler pilot goes out and need to reset daily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
brettule
I live in Australia (in the cold part) with a boiler which is 20 years old and came with the house. Last winter it ran fine heating all the radiators. I've since done a renovation, relocated the boiler and had a hydronic plumber recommission it. He says the boiler is in good condition and thinks it will run for another 20 years. I've taken a bunch of high res pics of the unit and markings here-> brettule.com/temp/boiler
Symptoms:
Unit is lit, a call for heat from the house thermostat starts the burners and it runs. An hour or so later I discover the radiators are going cold, the house thermostat is still calling for heat but the boilers pilot light is out. The pump is spinning still circulating cold water.
Troubleshooting and test performed:
I relight the pilot, it takes 2 attempts. The burners still do not fire up unless I press the reset button on the temp dial and burners then fire up.
I lowered boiler temp dial from 74c to 65c. The unit ran for several hours until the end of the schedule. Next morning I wake to find the house cold, the house thermostat was calling for heat but the pilot was out, pump was spinning.
Relight the pilot, it takes 2 attempts. Burners don't fire until I press reset button and burners fire up.
I lower the boiler temp on the dial and the burners go out, the pilot stays lit. If I raise the boiler temp the burners kick in.
With the unit running and a call for heat I hit the pilot off button. All gas goes out. I relight the pilot and the burners kick back into life without the need to press the reset button.
Thoughts
It seems that when I discover the pilot has gone out I also have to hit the reset switch. Perhaps the unit is tripping somehow?
Sorry mate. Not sure what the gas regs are down under but here we have a forum rule preventing us from giving you such information as could cause you to harm yourself unless you're a member of the class of people formally trained, qualified and registered to work on gas systems.
There's one of our members, oz-plumber, who might see this and advise you accordingly.
Otherwise the advice us to call a qualified tradesman in.
Croppie,
Same as ours, just read them upside down, thought you would have know that, simpliz
Reply to boiler pilot goes out and need to reset daily in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hi, whenever my Gloworm 18r is on even if I leave it on non-stop for 6 hours the flame symbol for the burner never switches off and the radiator...
We have an oil delivery booked for Friday but we ran out earlier today. We topped the tank with 150L from containers, bled the first boiler from...
I have a 40 year old floor standing Glow Worm 45-60 boiler (open vent )which is in a cupboard in the centre of the house. Its an old workhouse...
I have an older gas boiler HW heating system with a taco circulator pump for each zone that worked fine last season. When turning it on for the...
