Discuss Boiler pressure gets too high & cuts out with heating but hot water is fine! in the Gas Engineers Forum area at PlumbersForums.net
Hi!
I have a 9 year old Baxi combi boiler. When I turn the central heating on, the boiler pressure is getting so high that it keeps cutting out completely. It's absolutely fine when I run any hot water though. Does anybody know what the problem is likely to be please?
Thank you
There is an expansion vessel that is supposed to prevent this behaviour. It is evidently not doing its job and needs attention. There'll be a pressure relief valve that needs checking at the same time. Should be a straightforward fix for a heating engineer.
Reply to Boiler pressure gets too high & cuts out with heating but hot water is fine! in the Gas Engineers Forum area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
PSxxxxxx
