Discuss Boiler pressure is too low, filling loop in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all
Moved to flat recently, and the heating is not very good. I realized the pressure is too low, below 1 bar. It is Meibes, product number 10920.26 OH5
So I am looking how to fix it. I am only a DIY'er, so bare with me.
In the diagram you can see the fill loop mentioned, but that is not installed as you see in the picture. So, do I need to connect those two with a pipe/hose (?) and open the valves on both end to fill the pressure?
Those connectors are 1 inch wide, when I search filling loops, the standard ones look small, 15 mm? How can I find one fitting to here?
The two red valves with brass caps on eg the blue circled but the pressure looks fine and tbh the heating would still work with 0.5 bar in it so if it’s not it’s something else
Reply to Boiler pressure is too low, filling loop in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Folks, Where is the place to order a Vaillant filling loop, please? I looked around on the net but can't seem to find it as a kit. I'm not...
On my Valliant eco tec boiler the pressure guage is on red when cold . I drain a radiator to correct to pressure and it works fine and stays in...
Oliver1234
O
Hi, Just had a "Main Eco Compact" combi boiler installed as the Biasi one failed. It seems to work fine, gives a hot bath, i dont ever use the...
Hi, Non-professional / knowledgeable person here. I'm a Brit in Romania who volunteers for a charity building an old peoples home for needy old...
Hello! I have a combi boiler (n8 topline compact hrc 30/cw5) required to fill in 1.5 BA, 8 radiators, and heated floors in the same system. I...
