Discuss Boiler reset button needing pressed after hitting thermostat level - post bleed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
A few days ago our tank ran dry of oil, we got the tank filled and the bleeded the boiler (RDB2.2). The problem we are having is when the heating is turned on at the electronic control in the house it does not start unless we go out and press the reset button, at which point the boiler fires up and the radiators start getting warm. Once the boiler shuts off due to the thermostat it will not switch back on unless the reset button is again pressed.
What could be the cause of this?
Hello. Firstly, you are on wrong part of forum - you should post on the oil & solid fuel part.
Also you need to register with the forum properly with a username to receive replies.
Reply to Boiler reset button needing pressed after hitting thermostat level - post bleed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
