Discuss Boiler with direct rear flue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
woodsy
Been asked to change an old Ravenheat combi which has a flue directly from the back rather than the top flue elbow system and was wondering if anybody got any suggestions.
Glowworm i understand do it but not keen on the modern glowworm boilers. Because of stairs i don,t have the room for anything else.
Cheers
Glowworm are the only ones left now with a rear entry flue and they charge for it,as said not a great boiler,the smallest combi other than that is the remheha advanta (about 830mm) but you are going to have to have about 940mm with access to pipework underneath ,do not forget the flue does not have to come straight of the top of the boiler and out,it can go to the side and then out,maybe at higher point as the stairs rise
imho
Reply to Boiler with direct rear flue. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have just noticed a damp patch around where my boiler flue exits through to outside wall along with a rusty colour around the collar of the...
1K
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
J
Hi - I'm not sure if this is the right forum or not, but I'm looking for some advice with regards to a recent (nightmare) new gas boiler install...
4K
Mark Butler
M
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
