Discuss Boiler won’t pressurise and overheating in the Central Heating Forum area at PlumbersForums.net
Scott Laing
Got a Worcester green star 28i junior that was blowing off, replaced PRV now it won’t pressurise at all, just fills for a few minutes then blows out the PRV, heating and hot water still work if system not over filled. If bypass is shut boiler overheats and cuts out, thinking it’s the heat exchanger that’s blocked but very limited access to boiler so would rather advice before I start destroying the kitchen to get into it
What pressure are you filling it to? Could be expansion related issue, as for anything else removing the cover would be giving gas related advice, as removing the cover on that boiler forms part of the combustion circuit and needs checking correctly afterwards.
Reply to Boiler won’t pressurise and overheating in the Central Heating Forum area at PlumbersForums.net
