Discuss booster pump- A BIG ONE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Ted808
Came across what I think is a commercial booster , in a fancy house. She's not had it serviced in some time but that's besides the point. There is also a tank in the loft- all I want to do is turn it off so I can change a shower thermostat. The scared-y cat that I am I didn't want to turn anything off without knowing, as it's a fancy house- flooding is NOT on the cards. Any idea's? Either how to find out where to turn it off safely, or who to ask- she doesn't know.... IMG_20190327_151101447.jpg IMG_20190327_155144851.jpg IMG_20190327_155156097.jpg
So i can make out- in the dark- twin pumps and controller (not in pic) connected to the calorifier and as I said there's a tank in the loft. There are 4 lever valves- not labelled on the pumps- a pair either side. Tempted to turn both off but would like to also turn controller off. Dosn't help it's all in the bloody dark!!
Lets be logical. In a power cut everything goes off. When power comes back on it all works.
Just turn it all off! Isolate and Im sure youll be fine. Just make sure you test & drain as you go.
Should be a lever valve on the outlet of the pumps turn that off the blue tank is a water softener
Came across what I think is a commercial booster , in a fancy house. She's not had it serviced in some time but that's besides the point. There is also a tank in the loft- all I want to do is turn it off so I can change a shower thermostat. The scared-y cat that I am I didn't want to turn anything off without knowing, as it's a fancy house- flooding is NOT on the cards. Any idea's? Either how to find out where to turn it off safely, or who to ask- she doesn't know.. View attachment 37963 View attachment 37964 View attachment 37965
Turn power off and the delivery valve off and open the taps to depressurize the system and you should be OK. Label them to make sure no-one opens them.
That's the way I would do it. I can only speak for myself.
Should be a lever valve on the outlet of the pumps turn that off the blue tank is a water softener[/QUOTE
There are 4 lever valves, two behind and two in front, I tried to turn them but they are so stiff and it's so dark in there- I bottled. Will be going back shortly tho with better light.
Give it the beans
Something like this will be simple on off control with a pressure switch. Its just some relay type contacts, I'd maybe give the home owner the warning that "its not my fault if it doesn't work when I turn it back on". I'd expect isolation points down stream as well as up for an expensive system like that.
In the end she decided not to go ahead and refused to pay for the time I spent there trying to figure out what was what in the dark. Not too unhappy, as she didn't have the system serviced for the last 9 years as she lost confidence in the company that was doing it! Would've like to get paid tho!! Typically she was loaded.. Had to think about how many bathrooms they have!!
Reply to booster pump- A BIG ONE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
