Discuss Bosch 6.3ah battery? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi all. Any of you guys got these batteries and are they worth the money?
...only for specific high draw apps like a grinder, circular saw or if using your SDS for small cores.
For that money I'd get two 4A or 5A batteries instead.
no complaints for me using 1 6.0 lasts a bit longer than the 5.0 but nothing much
So I'm probably better off getting 2x 5ah batteries then?
yea did you get to the bottom if your sds problem afterwards?
Unless you really need the current draw or the increase in run time the 5ah are the best value option.
It's to use with my 18v sds. For some reason I only managed 8x 6mm holes in concrete with my 4ah batteries!
The Bosch warranty applies to batteries and chargers for 2 years, I'd retest my fully charged batteries and if they're still **** poor contact Bosch or your supplier before buying a new battery. You should be able to drill many more than 8 holes.
id sitck to 5ah batts, heard alot of 6ah are not as good on output wise as the 5ah versions so dont make a huge difference.
Reply to Bosch 6.3ah battery? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
