Discuss Bosch EasyControl CT200 in the Central Heating Forum area at PlumbersForums.net
Hey all, Ive a Greenstar 30i combi, looking to upgrade my current wireless thermostat to a easy control ct200. which adapter do I require to fit the boiler to control wireless function? TIA
You connect it through the EMS adapter in the boiler control box - port 14, I think. It plugs straight in. If you have no EMS adapter in the boiler you can configure it as a low volt thermostat switch.
If your question is how to configure the EMS protocol in your boiler to operate through Open Therm control that is also possible.
Ensure that you properly remove the old control system and replace the links
Reply to Bosch EasyControl CT200 in the Central Heating Forum area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW...
Hi all I have a main eco compact 30kw combi boiler installed. This is using weather compensation (baxi ifos) and salus iT500 controller. The...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
I recently had a Worcestershire Bosch 8000 Lifestyle installed but they also installed the inferior ESI control panel and wireless thermostat...
2K
I am considering replacing my existing boiler with the new 2023 Vaillant ecotec plus 625 boiler. I currently have 3 x Heatmiser neoStat...
