Discuss Boss adapter in the USA area at PlumbersForums.net
Anyone know the correct name and where i can get something like this boss adapter on the right?
Its solvent welded to the boss but is push fit to take 50mm pipe
Could use one of the rubber push in type but not sure how reliable they are
Reply to Boss adapter in the USA area at PlumbersForums.net
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
Trying to connect up new 40mm waste into the old soil stack (which would be an absolute pain to remove), it's all Osma pipe, from the 70s...
1K
[ASIDE: I did wonder if this was the best forum for this but figured as it was a boiler related issue that the gas engineers would be dealing...
Hi all, hoping you can help me. I have a leak where the bath waste pipe connects to the boss pipe. Not sure if its a push fit or pipe weld type...
1K
I think the markings on this boss adapter are to make sure its installed with the correct fall but im not quite sure what the makings mean and how...
