Discuss Both Water and heating valves opening when either system called for in the Central Heating Forum area at PlumbersForums.net
N
NikiInCambs
Replaced the head of a Honeywell 2port valve on heating and wired into an old block (S) like for like. However, when either water OR heating called for, both valves open!
Ideas?
Brown wire from switched live, blue, neutral, grey wire from permanent live orange wire to terminal 10, the m.valve end switch connects the grey wire to the orange wire.
Reply to Both Water and heating valves opening when either system called for in the Central Heating Forum area at PlumbersForums.net
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
