Discuss Bottle Auto Air Value in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need 3 auto air value for my CH system. Any suggestions to a good quality 15mm product. I was going to buy the unbranded screwfix ones but some of the reviews are terrible.
Thanks folks.
Put a decent lever valve before the auto air vent. Will make future maintenance easier. They all leak sooner or later.
there not designed to be left open you know so you will have to close / tighten the bleed screw?
have a look at a sprio rv 2
As above really. Most cheap AAV's will leak eventually and become a nuisance or do damage. There is a Commercial one I do rate quite highly but it will cost a pretty penny and probably be overkill on domestic. I would go for the manual as other suggest. Once vented a system should not suffer with air issues, as long as it has been installed correctly.
Reply to Bottle Auto Air Value in the Plumbing Jobs | The Job-board area at PlumbersForums.net
