Discuss Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
You can't have two ends open rick because air will go in though one end and push all the water out the other if one end is open atmospheric pressure is stoping the water escaping the one open end because it has no where to go it just stays in the pipes.
So bunging both ends makes the trap in theory?
Your college teachers must never have removed a rad in their life!
Lift it off the brackets & lower it to the floor.....? Firstly, you risk flooding the place & damaging the pipes & secondly, not all pipes will have movement to allow the rad to be raised while still attached to them!
No isolate the valves both sides crack the nuts both sides a little lift the rad of the brackets and lower it to the floor remove the nuts fully lift the rad up so the tails are at the top and pour water into a bucket.Ive seen it done with lcs and i built it and my brackets was on lock down lol.The teacher removed it because there was some one else waiting to have ago
You bung the vent and the feed because feed will push water though the open end flooding the place and the vent will push air in the pipes also resulting in flooding the place. When you bung a system you stop any water or air getting in the system because that will push water out the open end.
You can't just lower it on the floor you will get black water everywhere you need to empty the remaining contents into a bucket.
It's all practise and experience. To start with do it how you're comfortable. Once you've had a couple of bad experiences with open vented drain downs chasing air locks about, that's when you realise that many a time a drain down is not the way to go. I remember going to a house on a Sunday morning, not long after I started on my own, trv leaking, had a quick look and it had split the olive, but it was a funny 1/2 olive and rubber o ring. So thought no problem I'll drain it and change the valve. Twenty minutes later I'm filling the system up thinking champion. Four hours later I'm still trying to fill the system up and get all the rads working.
So you would leave the rad mounted in position isolate valves,undo the trv and drain into a bucket then remove radiator?
How did you chase the airlock out in the end?
Yeah rick don't want to mess the custards carpet up. Iv had an airlock on a sealed microbore system before i just filled the system up to under three bar that sorted it! Then drained down back to 1.5 when all the rads where hot. If a open vented rick you could blow down the vent use a wetvac to blow down the vent open the bleed tapping on a rad and open the valves.
Back filled with mains, disconnecting pipes and pulling water through em, turning pump on and off and a lot of patience. It's easier with an oil boiler as you can boil it out with a bit of practise.
I've used this method quite a few times where there is a bit of movement in the pipes. Just shut off the valves, slightly loosen the nuts, lift the rad off the brackets and lay it down. Undo nuts completely and stand rad upside down, fingers over ends and take it outside to empty it. Nice quick way of swapping rads as long as you have a few towels to catch any spilt water as you take it off.
New posts
Reply to Brass fittings in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced...
Where the black polyethelene service line enters this particular structure is by far the most freeze-prone area. The structure is an elevated...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop...
Hi folks Really daft question here but what tap connectors are you all using? I’ve picked up a couple of end feed with fibre washers today and...
