Discuss Bristan 1901 recessed shower valve assembly in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
We have a shower like the atatched pic with Bristan 1901 on the cap.
I had an issue with the shower leaking from under the handle and the odd time the water was gushing out.
I contacted showerdoc and bought replacement seals. That didn't seam to work only made it worse i.e. more steady dripping now.
I then bought the replacement cartridge (CART 5) and fitted as per the instructions. Now I found the small cap (sits behind the temp handle at the front) would not fit on the cartridge splined end.
The cap slides on/off the original cartridge with ease.
I'm assuming the same should be the case but I don't want to tap/bang it on in case I cannot remove or ruins the cartridge.
Is it commly very tight to get on?
Regards
Reply to Bristan 1901 recessed shower valve assembly in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
