Discuss british gas 532/1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
this is badged up boiler but what boiler is it,very similar to baxi duo -tec ,but not sure.
if you haven't got it for tomorrow I'll walk all the way outside and get smi lappie out if van and look
It's a worcester greenstar I believe desrob :) Not sure if its the junior or CDI?
same reason they re-badge everything else, so the average punter will go to BG if anything go's wrong. Think that only BG will have replacements. :dupe:
it's to make people think they are much bigger. "oo they must be good they even make their own boilers"
Reply to british gas 532/1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Article
A Plumber Who Worked Illegally Gets A Suspended Sentence After Falsely Claiming To Be Gas Safe Registered. A Plumber in Herefordshire was prosecuted after Hereford Trading Standards Team found that he was falsely claiming to be on the Gas Safe Register when he was not, putting members of the...
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
