Discuss Builders opening with pipes inside in the DIY Plumbing Forum area at PlumbersForums.net
Hello Everyone ;0
Iv just discovered this forum, looking through internet to find a solution to my small problem.
So I just reopened, builders opening in my 1930 ex-council house. And surprisingly, did find some pipes inside.
Two look like water - those have been cut, and those are like side ones. but one looks like a gas pipe. Can anyone confirm that - then I will need to find some gas engineer, who will sort it out. Or is it just a water pipe and I can cut it myself? I'm able to cut and seal water cooper pipework, but I don't want to touch gas pipes!
Anyone can help me with that? I did attach some pictures
Thank you for any input on this subject!
Rafal
Small one is a gas pipe
Reply to Builders opening with pipes inside in the DIY Plumbing Forum area at PlumbersForums.net
