Discuss Building regs, regards zoning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Hi guys, just a quick un. Has the regs changed for zoning of levels? I’m doing some some new builds and the architect has said that all houses regardless of floor area has to be zoned... ie upstairs/ downstairs. Anybody heard this?
Yes or anything over 150m2 foot print (open room)
I’m aware of the over 150m2, these houses are poxy 2 up 2 down and about 50m2 footprint
Every home must be divided into at least two heating zones, using a thermostat controlling a motorised valve.
If the house is smaller (less than 150m2), then these can be controlled by the same timer.
If the house is larger (more than 150m2), then each zone must be controlled by its own timer.
Every radiator should be fitted with a radiator thermostat, unless it is the reference radiator for a thermostat
(i.e. the radiator where the room thermostat is fitted).
Yep, thanks Darren. Have you a link to a piece of official data for this please.
Reply to Building regs, regards zoning in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
