Discuss Called out to fault on Alpha HE 33. New Fan Installed. in the Gas Engineers Forum area at PlumbersForums.net
Hi guys. First post on here. Called out to fault on Alpha HE 33. Fast blow fuse found to have blown. Faulty fan found to be problem. New fan installed and tested. Four days later and a call from customer to say boiler not working again. fast blow fuse found to have gone again. Replaced and gone again three days later. Anyone come across this before. Any pointers would be welcome. Starting to think wiring loom maybe
Could be pcb fault, water leak, pump, how do you know it was the fan.
Are you qualified to be tinkering in there?
Stu
am qualified GSR engineer. Fan was replaced after a process of deduction by disconnecting mechanical parts, fan, pump, gas valve, diverter motor etc. Everything worked ok with fan disconnected and fuse didn’t blow. PCB ok and no water
Reply to Called out to fault on Alpha HE 33. New Fan Installed. in the Gas Engineers Forum area at PlumbersForums.net
Started getting a random F7 fault on our gas boiler, called out a gas engineer to have a look at it. He gave it a good look over and checked and...
This sounds like an examination question but it really is a problem two different plumbers have been unable to resolve after spending several...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
Hi All, I have a Worcester Danesmoor 20/25 oil boiler which is causing me lots of heartache and grief. About 3 months ago it locked out and...
2K
Hello All, First post here, I confess to being wet behind the ears with Baxi 105e major problem so its Urgent! It started with Flame Failure...
3K
