Discuss Camray 5 combi 90A switching off after initial burn in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Camray 5 around 14 years old which switches off after the initial 15 min burn. The wall thermostat has not clicked off. If I then either turn off the power or click off the wall thermostat and then back on again it comes back to life. It then does the normal procedure, burn for a few minuits then off for a few minutes then back on until the wall thermostat clicks out. This is a intermittent problem somtimes it works ok.
Last October I replaced a leaking 3 way motorised valve body. I had this problem on a regular basis before I replaced it. Then afterwards the problem disappeared until the other day after I had taken the top cover off to check for leaks as the pressure had dropped very slightly to 1.25bar over a period a few weeks. Did not find any leaks. I topped up to 1.5 bar again. After this the cutting out started again. When it cut out this morning I started to take off the top cover and as I was doing so it started again.
Doesn't sound like much. It needs servicing properly every 12 months. My advice is to get an oil tech or heating engineer out to service it and explain the issue you have.
I think what they're alluding to is that it's not a diy fix
The problem is intermittent and might not be there when he's. here I was hoping someone could point out where to check. Ive fixed Tv's over the last 45 years so Im not about to kill myself. Ive checked the wall thermostat connection to the boiler and thats ok. I read some thead about sticking micro switches.
There's a lot more to it than you might think .
Please don't mess with it. Get someone in.
I understand a TV is an electrical appliance but it doesn't have pressurised fuel or a risk of Carbon Monoxide.
Anyone remember the nuke submarine commander with the wooden cabin in the Scottish Highlands from a couple of years back?
He took the flack he got in good faith eventually.
Reply to Camray 5 combi 90A switching off after initial burn in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a green star ten yrs old keeps increasing pressure, feel on off filling valve not working, drain off to recommended, but after few days...
