Discuss Can an old mixer tap leak uncontrollably? in the USA area at PlumbersForums.net
R
Richard Ryan
The mixer tap in my kitchen is very old,maybe nearly 20 years. For the last year or so it has been leaking and getting worse. Get it replaced you say. Not as simple as that. The pipes into the house are very old lead pipes and years ago did leak where they come into the house, fortunately above ground. If the plumber wasnt able to fix, he said the whole pipe from the mains would have to be dug up, a massive undertaking. And to add to matters, the property is sold subject to contract. The mains outside doesn't turn off completely but again I'm loathe to contact the supplier as again I'm concerned it could cause bigger problems. Any advice???
Contact your water supplier and tell them their stopcock isn't turning off properly. Not much you can do until they fix that.
Reply to Can an old mixer tap leak uncontrollably? in the USA area at PlumbersForums.net
