- Messages
- 5,073
As perviously posted by others the problem is proving it was installed correctly in the first place, perhaps it was overtightened & that has caused the soft brass nut to expand & finally spit when pressure was greatest (overnight) ?
Did you test it ? BS 6700 calls for ridged pipework systems to be tested to 1.5 times there maximum working pressure, this way any problems can be found & repaired under controlled conditions.
Your hand, in making a claim is either greatly enhanced by testing or reduced if you didn't.
