Discuss Can i put a grill / mesh inside an obsersation chamber? in the DIY Plumbing Forum area at PlumbersForums.net
Hi - I'm looking to install an observation chamber which will have 160mm pipe running in and out of it. I want to catch any debris in the observation chamber before it exits ... probably a small grate with 10mm squares catch everything I need. Would would be the best way to do this? should I try to fix a grate on the inside of the exit hole of the chamber?
Thanks for any advice.
Reply to Can i put a grill / mesh inside an obsersation chamber? in the DIY Plumbing Forum area at PlumbersForums.net
PSxxxxxx
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
