Discuss Can I use a Franke tap with a Carron sink? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello there!
I have a Carron sink and tap in my kitchen and I'm wondering if I can replace the Carron tap with a Franke tap?
Many thanks!
Is that it Dave? No mention of pressure, flow or wanting a picture? :p
I'll post pictures if it helps. Not sure about pressure, I'd say we have high pressure as we have gas and the water supply comes direct from the mains to the house.
I dont know what flow is.
I'm assuming most taps have the same fittings and are a standard size?
Reply to Can I use a Franke tap with a Carron sink? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a Franke Planar Kitchen tap and it’s got a leak. One drop per minute. I’ve been on YouTube and seen that there are grub screws to...
Hi I have a kitchen mixer tap which allows the top part to pull out as a hose (like american sinks). It has frayed and I need t replace it, can...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it...
Have a sink basin tap photo attached and need to replace the heads as behind they have cracked. Any idea where I can get replacement tap head...
