Discuss can multi zone under floor heating use internet room thermostat? in the Plumbing Zone area at PlumbersForums.net
bluesky
Dear all,
this is a 4 zone underfloor heating system, i normally use wunda room thermostat, but this landlord wants to control the system on mobile phone, I used IT500 before but that is volts free and for combi boiler only,
Has someone had this problem before?
Many thanks!
If it has been wired with a 3 core + earth. You can use Heatmiser neostats. They do one for hot water too. The Wundafloor stats need the same wiring. They both need a 35mm deep box in the wall.
very easy to fit and set up.
Have used ufhtradedirect.com a few times, and also heatmisershop.com
Neostats or Honeywell Evohome if mixed ufh and rads... (Honeywell also do the DHW)
Reply to can multi zone under floor heating use internet room thermostat? in the Plumbing Zone area at PlumbersForums.net
