Discuss Can you make neatly cut plinth for a WC pan with just a jigsaw? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
As - apart from a multi-tool - I have no other wood cutting tools.
yes just takes time
you can make one with an AXE!
just take some flat pvc capping with you and silicone it around after install.
Wife fitted door with a bread knife, but for those of us who fall short of such carpentry skill, a rectangular plinth, neatly tiled may provide a simple option.
Do you mean something like this?
[DLMURL]http://www.wickes.co.uk/Wickes-PVCu-White-Cloaking-Profile-30-x-2500mm-Pack-5/p/162618[/DLMURL]
yeh, but get the thin stuff about 1-2mm thicck. bend it to shape, silicone it on and pin it at the back.
do it right and cant tell if its not part of toilet.
Any idea where you can buy just one strip of the 1-2mm stuff? And what would you use to make the plinth out of?
Reply to Can you make neatly cut plinth for a WC pan with just a jigsaw? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
