Discuss cannot find return pipe for bathroom radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bluesky
i have converted a regular boiler to combination one, there is a 15mm pipe after the pump and i found it was the flow for the radiator in the bathroom, however this radiator is not hot although all the others work fine, i am thinking something wrong with the return pipe but cannot find it at all, anyone has met this kind of thing before?
cheers in advance
Hi mate it sounds like the old radiator was run from the primary flow and return. What did you do with the old primary return pipe work? Did you just cap it in the airing cupboard?
what are you saying ? that there isnt a flow and return pipe ? just one pipe ?? think a picture or two may help
Are you saying there is only one pipe connected to the radiator ??
As APPlumbing says in the old days it was common to run a rad off the primary flow and return so that you had heat in the bathroom for drying whenever you had the system set to heat water but as in summer you did not want the house warmed. You will need to track the pipes and re-connect. Sometimes on older systems this rad was on a gravity loop but this depends on the age of the property.
many thanks all,
i removed the pump, capped the flow for DHW, connected the primary flow and primary return, there is a bypass and i capped it, there is a 15mm pipe going to the bathroom radiator, however i cannot find a 15mm return pipe for the radiator, the pipe for the radiator is under wooden floor, how can i get sure it is connected to the primary return already?
Reply to cannot find return pipe for bathroom radiator in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all, I live in a flat that has communal heating through a single pipe system. I recently had replaced a deco flat panel (waffle) radiator...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
Hello folks I've moved into a property last month and started to note things that may need looking at. Some of the radiators on the ground floor...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
