Discuss Cant find 15mm bypass valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
gungaabayar
Hi
Need to change bypass valve, cos it lets water through even it closed position. seems like knackered.
I was looking a similar one but cant find 15mm bypass valve, All I can see on the market is 22mm auto bypass valves,
so what kind of bypass valve I need to replace it with? and is there a place where can I find 15mm bypass valve which is similar to the one in the photo attached?
another silly question is which way I need to turn to close (or tighten) it clockwise or anticlockwise?
cheers all
You have a manual gate valve. ( lockshield) it will be set in one position and will let water bypass all the time.
You can replace with a 23mm bypass and get compression reducing sets for each end or danffoss make a15mm version.
Danfoss Randall Avdo15 Auto By Pass Valve 15 Mm - BHL
blimey its quite expensive,
anyway, as for my current bypass valve does it look like I need to turn it anticlockwise to shut the valve? why Im asking this silly question is the other day a plumber visited me and told that the gate valve turns other way around (anticlockwise) to shut it, I dnt wanna try it in case it looks too old and may comes off if I turn it wrong way!!!
cheers
Gatevalves (Lockshield as yours is) turn Clockwise to close.
And it doesn't matter that it lets water through when closed, a manual valve shouldn't ever be closed, it wouldn't be a bypass if it was.
If the Auto is too expensive then;
https://www.toolstation.com/m/part.html?p=68362
thank you very much,
there is a shield in the gate valve and I took it and but cant turn it anticlockwise, so tried to turn it clockwise easily but little water come out and so I turn it back (anticlockwise) , seems like the gate valve is all the way open, thats why it lets too much water through it,
does it look like all the way open please have a look the photo attached in this post?
Im thinking only position the valve is not leak is all the way open, am I right?
cheers
gate valves tend to become useless about 5 years after fitting in my experience
There should be a shroud over that. Put it back on and nip it up, it seals the gland.
thanks for your advice,
I dont wanna try it now, cos Im planning to replace it in this coming weekend,
thank you very much indeed
if I buy 22mm straight ABV for 15mm pipe then what kind of reducer I have to use ?
any web link or photo are there please?
it might be one end is 15mm compression and the other end is just 22 mm pipe?
cheers
You have 3 options
1: get two 3/4 to 15mm female irons and use some pride/loc55 on the bypass threads
2: get two long internal 22mm - 15mm reducers (soldered)
3: get two pieces of 22mm tube and solder some external / use couplings and reducers
You have 3 options
I prefer first one cos im avoiding soldering.
So is it the one you said in option one? Please click on the next weblink.
15mm x 3/4'' Compression Female Iron Coupling
Also can I use ptfe instead of thread sealant loc55?
System might not even need the bypass if it's a y plan with a bypass radiator etc... I find a lot of old system just have them fitted. If you do replace it an auto one would be better than a gate valve type...
You have 3 options
I bought what you said here, but 3/4 female connector doesnt fit, the female connector is little small for 22mm compression thread
I bought following coupler from screwfix, Female Coupler 15mm x ¾" | Compression Coupling | NoLinkingToThis
Or did I buy wrong one?
Reply to Cant find 15mm bypass valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
