Discuss Can't find UFH manifold vent/drain valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all,
I can't locate the vent/drain valve on this manifold.
My manifold resembles the "UFH Manifold RUB-RT1tm4" model on this webpage: https://www.thermo-floor.co.uk/underfloor-heating-manifolds.html
I an intending to replace on the the actuator pin-valves and I think I need to drain (or at least depressurise) the manifold to do this. I see a bleed valve on on the top left, but I think I need a valve on the bottom of the manifold to allow it to drain.
Is it possible for anyone to help me with this?
Many thanks,
Bottom of the pump air tap / drain
Top left air tap to vent
Reply to Can't find UFH manifold vent/drain valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
