Discuss Can't find UFH manifold vent/drain valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi all,
I can't locate the vent/drain valve on this manifold.
My manifold resembles the "UFH Manifold RUB-RT1tm4" model on this webpage: https://www.thermo-floor.co.uk/underfloor-heating-manifolds.html
I an intending to replace on the the actuator pin-valves and I think I need to drain (or at least depressurise) the manifold to do this. I see a bleed valve on on the top left, but I think I need a valve on the bottom of the manifold to allow it to drain.
Is it possible for anyone to help me with this?
Many thanks,
Bottom of the pump air tap / drain
Top left air tap to vent
Reply to Can't find UFH manifold vent/drain valve in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Do people with this type of mixed flow temperature control have any problems with achieving the required manifold flow temperature? The one below...
Hi Everyone I wasn’t sure whether to post this in here or UFH but hopefully I’m posting this in the correct group. I’m in the throes of a full...
Hi folks, hoping someone can help with a problem that's been perplexing me since just before Christmas..... I have a wet underfloor heating system...
Hello, I have UFH set up with a HIU in my flat. My issue is that one zone (Bedroom 2) does not heat up. All other zones working and heating as...
I am doing heavy house renovation and want to have ufh (multizone) at the ground floor and radiators on upper floors. I want to have consistent...
