Discuss Can't get a plumber - DIY advice in the USA area at PlumbersForums.net
I'm renovating a house. Can barely get ANY tradesman (I need alot of work done). Did all my own electrics - now for plumbing!
I want to use six 4-rail manifolds(pictured) to run 10 radiators. 3 for flow, 3 for return attached to 22mm. Located in a central place (under landing floorboards) then 15mm speedfit to each rad. I like the idea of a central connection as the landing will be laid with carpet that can be pulled up. The tiles and laminate flooring in the other rooms cannot (well, without cost anyways!)!
Good? Bad?
The CH is holding up things. These days, anything I can do myself, I will do it. I can push some pipes together! And, TBH, I can chase the walls (downstairs will need that as there's a concrete slab) and bury the pipes properly. I honestly don't have a plumber I know and trust to do this properly.
Oh, and a new boiler will be installed when I can finally get a plumber.
Thanks a lot.
David
Thatā€™s fine just use home runs (no joints other than manifold or rad) and mark each pair back to a central spot
Good or bad?
Good for future maintenance
Bad if you need to drill dozens of holes in joists and will probably use lots more pipe
Using routes from the previous installšŸ‘
Plumber was only 144 per radiator, chased. That was an estimate though, not a quote.
I won't even save much, but done right guaranteed. And I'll learn for the next house!
Cheers
Reply to Can't get a plumber - DIY advice in the USA area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
