Discuss Can't put hot water on without putting radiators on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nelster
I have an old Baxi wm 512 rs boiler. I live in an ex council flat and they seem to have put these in every flat. Every time i want to put on the water only, the heater comes on..
Anyone know what I can do to fix this?
Any help gratefully received.
motorised valve is most likly possibly roomstat if you have either. Some old council systems just had a manual gate valve to shut the heating or a flowshare divertor valve
Thanks for your answer....
.. Sorry to be stupid.. but what does 'motorised valve is most likly possibly roomstat' mean. Where can I find the manual gate valve to shut off the heating when i just want hot water.
thats why it is a motorized valve - its automatic. unless it was installed by a decent plumber, there will be no manually operated gate valve to shut! if you could post a schematic of your installation we may be able to help further, otherwise it's gonna be difficult!
Reply to Can't put hot water on without putting radiators on. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
PSxxxxxx
