Discuss Capping 40mm Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stanios
Hi all,
Got a kitchen waste that needs dropping, so will need to cap the 40mm waste coming out of strap boss. Space is at premium, is there an actual cap in existance for 40mm solvent weld or do I have to make it coupling + rodding eye?
Cheers
They do a Compression cap end, if you don't want compression coupling and eye
Boss already got 40mm glued into it so need a cap that ideally goes inside the 40mm or at least outside so I dont have to coupling rodding eye which takes up alot of space.
Yes!
Reply to Capping 40mm Waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
