Currently reading:
Capping Off 63mm PVC pipe ?
Discuss Capping Off 63mm PVC pipe ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Thats Ballcocks
Hi, need to cap off 63mm pvc pipe (deadleg) I have measured circumfrance which is 200mm. which equals 63mm. but I see there is also 2", does anyone know if there is 63mm comp. cap for this pipework as once cut I am comited. Any ideas? thanks.
Can you chop off a slither and take it to the merchants. With so many different types of fitting it might be wise
63mm mdpe cap is about £5. if your unsure of the size get a few and take back the ones you dont use.
Hi. this is pvc pipe from main storage tank, cannot cut sample.
No Scott, PVC, I have now ordered a Flexi cap ( stainless steel band type) as this pipework is not pressurised.
Reply to Capping Off 63mm PVC pipe ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
