Discuss Cast Iron central heating in a church, should we upgrade? in the Central Heating Forum area at PlumbersForums.net
Hi All, I'm after a bit of advice about our church heating.
We have a cast iron central heating system in the main church building that has recently suffered a leak where it joins onto the newer (circa 10 years old) boiler feed steel pipework. Finding a contractor who wants to work with cast iron was interesting! The radiators themselves appear ok, with most of the pipework between radiators seeming to be ok, though the valves are a bit worse for wear, some weeping slightly from the valve stem.
My question is, do we replace the whole system, or keep the radiators and just replace the pipework? Getting modern radiators to give the same output as these 2m wide 1.5m high monstrosities would require massive modern radiators I expect.
Any advice would be greatly appreciated.
Unfortunately replacing would be best part of 100k depending on size
as for finding someone best to find someone who does commercial repairs
as for valves leaking they may want a nip up on the packings or rebuilding
I would keep the cast iron radiators because I think they look pretty. They also have a large thermal mass, which can be advantageous.
Are the pipes really cast iron? New and old steel pipes can look different because the new are often galvanized and look silvery, and the older ones are black. If they are both steel, then I don't see why a good connection cannot be made. Can you please post a pic of the pipe connection between new and old where they are leaking?
If they are really cast, I have no experience with that kind of pipe.
The leaky stems on the valves on the rads are easy to fix, you just loosen the little nuts off, wind some rope packing around, and re-tighten them.
Sounds like a proper job!
Would be really hard to define the work needed to repair even after seeing and imagine most would push towards replacement.
Have you looked into warm air or radiant heating?
Hi All, thanks for the replies.
I sent the post, then had a hectic few days! I'll get some photos of the area, but I'm now leaning towards leaving the original radiators.
The pipework that leaked had split at the connection between the original cast iron, and the newer steel pipework when the old oil boiler in the basement was replaced with the gas fired combi boilers in a new boiler house. After talking to some of the older members, this was all done around 25 years ago (I was 11, so only vaguely remember it) so the boilers are getting on a bit.
It doesn't sound like there's a great risk to the radiators/pipework failing further, but with the boilers being that old, i think we might be best using the money we do have to replace the boilers instead.
We have a budget of around £25k, which doesn't sound adequate to replace the whole system!
I think I'll recommend the boilers for now, and get a quote to replace the current radiators with the fan assisted rads a few have suggested. Then we'll know how much we need to have saved up in order to carry out the works on one go.
I would get some pics first then we can advise as much as you can eg boilers pipe work, where the split etc
I took some photos of the system today. Firstly the boiler house. There is 1 x Vokera 28 SE Mynute, which I think was replaced in 2005, and 2 x Vokera Linea 28 that were installed new in 1998. The running time on the Mynute is 1319hrs, and the Linea's are 12257hrs and 6689hrs. There's a Heatmiser control that's supposed to share the hours, but it isn't working too well between the two Lineas!
All 3 boilers are linked to a low loss header, then there's a pump that serves the back hall, corridor, toilets and creche room. That has been previous upgraded to 1 inch steel pipework, and modern rads about 8 years ago.
The other pump serves the main church and the front porch, which is all still original cast iron pipework and rads. I think the pipework is 3 inch, but the pipes leaving the low loss header are only 1 inch, so not ideal I don't think.
This is where the cast iron elbow cracked, and has now been replaced with a steel fitting.Steel to Cast Iron joint.jpg
This is an example of one of the leaking valves, only 4 out of the 15 rads are leaking, with this one being the worst.
This is an example of the 8 radiators in the main church, i hadn't realised they were up on legs, so not as big as I thought, 1m tall by 1.2m wide.
The pipework leaves the boiler house and goes down into the old underground boiler house, then enters the left side of the church and leaves the right side, at that elbow, or it might be the other way round, not sure!
Sorry for the large post, but any advice would be greatly appreciated in how best to protect the system, without spending more than around £25k.
Thank you!
Standard steel pipe system any commercial engineer should be able to sort this make sure they have done steel pipe work before cutting and threading
Agree boilers need changing and re doing as that high boiler isn’t good as it’s too high
The leaky rad valves just need there packing gland tightening and the rust removing and painting (don’t keep opening and shutting these valves there not meant for this)
The rad that is on legs it’s been piped up as it’s on a one pipe system for some reason this need investigation too see if the others are piped in the same
Would be nice to maintain the pipework and rads to keep original.
You've got 3 boilers cycling so can swap them out when you like?
The big issue here I think is going to be 'too many fingers in the pot'.
Find a good firm that isn't desperate to convert your 1 pipe and peper the system with bits of copper and hold on to them!
Reply to Cast Iron central heating in a church, should we upgrade? in the Central Heating Forum area at PlumbersForums.net
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
A bit of an unusual topic, as these are very rare in the UK. I went back to Poland to commission, test and tune the 20kW solid fuel boiler and...
N
Hi! We're looking for a consult for our 1905 built (renovated in 2010) victorian house for the future of our heating system. The house is 2...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
