Discuss Cast iron question for the mature lot on here. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Morning all, just a simple question for the forum elders:D
What size cast iron is 95mm OD, would I be correct in thinking 3.5” old school?
Thanks in advance
Hi guys, the existing cast iron stack is very very old... maybe centuries old. So could I say that it is probably old 3.5” internal stuff?
Ok Bog what are you planning ? is it a listed building ? you will get battered if you biff it down. Sends us a piccy there is look alike 'cast ' plastic stuff. If its internal then cut it off down low..not too low get a ring on it into plastic and OFF you go
your 95mm and 3.5 inch is right BUT if is really old ...more than I am then ...the od tolerances can be a challenge...often a Multi Kwick will get back onto modern stuff, its not nice but works.....from
Old Central Heatking ! I will have to tell my new wife oh dear. centralheatking
Reply to Cast iron question for the mature lot on here. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening I've came across 90mm cast iron before and used mcalpine extB (90 to 110 extension) But what I have here kind of bellows out to...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into...
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
1K
Morning all. I hope this is the correct place for this post. If not i'll happily move it to another forum area. I am renovating a property and...
