Discuss Cast Iron toilet waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
U
Unregistered
Hi all,
I'm currently replacing my toilet but whilst removing the waste pipe the cast iron section has broken off half way in the ground (concrete floor). Is there any was to insert new PVC piping into the existing cast iron pipe or do i need to dig down until i can reach the top of the pipe and connect a new PVC pipe onto it? Thank you
Welcome along. Please register with us for answers as there is likely a number of solutions and pictures would be useful
Reply to Cast Iron toilet waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I need to this cast iron pipe back as my new back to wall toilet won’t fit otherwise. Cutting it back i am going to lose the collar. So what...
I will need: install new 100mm pvc pipe work, 90-degree bend for new W/C install new 100mm pvc pipe work, 90-degree bend with new gully pot at...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind...
Hi, Helping a friend, his soil stack is cast iron. The bath and basin wastes (all removed now) went into individual entries on the stack. These...
Good evening I've came across 90mm cast iron before and used mcalpine extB (90 to 110 extension) But what I have here kind of bellows out to...
